Driveshaft issue??
  Clio 172 cup
I've got a gearbox oil leak by the ns driveshaft I think it's the driveshaft seal can I replace that or is it part of the driveshaft
  Clio 172 cup
Any ideas folks I've seen some gearbox oil seal kits on eBay is that what I need,I don't no much about the driveshafts etc
  Renault Clio 172
you need to measure up the diameter then phone renault for a replacement, i think there is a couple of different sizes.
its easy enough to change but you will have to drain the gearbox first and need a pair of circlip pliers to take off the tri pod bearing thing on the end of the shaft
  Clio 172 cup
Cheers bud
  Renault Clio 172
