droning noise since 40 mm springs
  Clio 1.5 dci
ok, so about a month ago i had a set of 40mm apex springs fitted and ever since I've had a drone coming from what sounds like the back two wheels, it is very hard to tell if it is one or both.
my first thought was a wheel bearings but i thought to my self what are the chances of both going at the same time and it coinciding with having the springs fitted so next i thought rubbing but no matter from which angle i look i can't see anything which is remotely close to the tyre.
my other thought is that the people at the garage when putting the wheels back on have put the rears on the wrong way round and if the tyres had a direction they would both be running backwards but i can't see an arrow on my tyre so have no idea if the wheels are the wrong way round or if the tyres are directional at all.
has anyone else had a similar problem or got any ideas? any help would be much appreciated.
  Clio 1.5 dci
but it sounds as though the noise is coming from both while driving, how do i ascertain which side it is coming from?
  Clio 1.5 dci
Ok well I'll have a look tommorow any idea how much roughly a garage would charge for a bearing to be changed?
  2014 Clio 200t edc
Change them both yourself for about that, £110ish should get you discs, bearings and pads.
  Clio 1.5 dci
turned out it was the wheel bearings, one was absolutely fucked and the other on its way out so i had them both changed by a mate.
