Dual Optics
Car  2000 Clio 1.2
Hi i have dual optics on my Clio Mk2 Ph1
And my drivers side is perfect but some reason my passenger side is dim when on main beam, anyone know what the problem could be
Also can anyone tell me if mine are set up properly by these pics, i mean are the correct lights lit up for the correct setting.
Sidelight
Main Beam
Full Beam
dodgy wiring?
bad bulb?
corroded connector?
could be anything really, but id start with the above,
maybe get a multimeter involved to check the voltages
but yes, the correct lights are showing in the pics included!
I doubt its a bad bulb as i have replaced both at the same time the wiring looks alright and not corroded but i will have another look in the morning :) thanks for the reply, and phew, thank god there all the right ones showing lol
Chnaged the wiring, still not the same brightness, changed the bulbs, still not the same brightness, anything else that could be causing the problem ?
