Easiest way to get to oil filter?
  monaco 172
As title really, what's the best way of going about it? From underneath or above? I just can't get my hand to it lol.
Also, quick question about how hot it should be running ? I've noticed that even after almost 2 hours after drivin the engine is still hot, the plenum stays really hot.
easiest to take the fuel rail guard off. they'll stay warm for quite a while; doesn't sound unusual, although shouldn't be 'hot' after a couple of hours
  monaco 172
Please explain, couldn't find a guide.
Where's the fuel rail? And does this then mean going in from above?
  Ph1 172 + Combo van
Take fuel rail gaurd off as said. 2 X 10 mm bolts iirc or maybe 13?
Then you can get some grips on it.
  monaco 172
Does this fuel rail guard thing have holes in the front? Mines a bit rattly if this is it? I think I know what you mean.
Yeah has holes and a sort of criss cross design on the front edge of it. Just whip that off and it's easy to get at the oil filter.
  monaco 172
sorted, looks easy enough to get to.
My fuel rail guard has got 1 of its bolts missin, wondered why it rattles. Look like very odd bolts aswel.
When removing the filter is it advisable to cover up the sensor below to the right of the filter as i can see oil getting all over it.
