HI I am new here, i need some help with my mate clio 1800cc 16v mk 1, thinks its 7p engine code thingy...
Problem is its failed MOT on emissions test....
Co 0.80, no lower, hydrocarbons low 88ppm
so i thought it would make sense to drop in here , hopefully get some useful information..
i am looking for any info relating to scanning software, ecu obd software, or a simple stand alone ecu code scanner, as i believe the problem lies in a sensor failure, not wishing to remove all sensor to check it would make sense to check ecu for error code.
so one of you helpful guru's here should point me in the correct direction..
cheers
DaJon
cheers
DaJon
