ECU Decode + Emulator?
Car  F4R'd Mk1 Clio
Need some help with the wiring for my mk1 f4r conversion.
Someone told me a while back that you have to run a phase1 172 ecu have it decoded but then weld an emulator to it so the ecu thinks it hasnt been decoded?
If so where can I get my ecu decoded, is it a case of sending it of to company to have done?
Also where can I get an emulator? Is there a guide on how to weld it on maybe?
Saying all that Ii just read in beanies project thread that he just had the imobiliser removed from the ecu?
Any info you have would be realy usefull.
Cheers!
As far as I'm aware you simply need to send the ECM to somewhere like ECU-Testing to have the Imobiliser code removed... then wire it up and watch it go.
Mick
