on a mk1 Clio 16valve does the ECU need reseting when you change the engine?Thanks
R RobW Feb 1, 2004 #1 on a mk1 Clio 16valve does the ECU need reseting when you change the engine?Thanks
BenR Feb 1, 2004 #2 when you change the engine the ECU will be unplugged anyway, as will the battery.
