Is that in comparison to a FF 172? Renault developed totally different shafts for each?i know on the 172 cup they are completely different lengths with different mounts at the gearbox end.
maybe the cup shafts are like the sadev ones??
the ff's have equal length shafts.
hell no!
No point shock shafts are fine strenght wsie to use 182 ones you'd also need to change the hubs and the wishbones.Hi there, this is my first post and I am sure it is a n easy one. I am thinking about upgrading my 172 with 182 cup hubs and drive shafts. The upgraded shafts look different. Does anyone know if this will have an adverse affect with my ABS?
The driver side has a point which hols the shaft to try and make them more equal ie the pasenger side shaft has a bit sticking out and held by the box.to keep it rigid.hows that work, when the the gearbox is bolted to the right side of the engne? :S, one has to be longer than the other!!
Well I've got the hubs too, Are you sure about the wishbones?
