Electric car polishers
Can anyone recommend a decent one? Had a cheap one in the past from halfrauds which was so shite lol..
TBH any of the DA machines will be fine for a beginner, all depends on what pads and polish compounds you use.
I went for the above purely as it was the cheapest and I don't intend on using it often
I went out and bought that silverline rotary polisher, having never used a machine polisher and it's a piece of piss too use, just don't be stupid with it and you wont do any damage.
^^^ Yes I did the same. But there are times when a DA is better. You dont know how much paint is on the car to correct, therefore your more likely to burn through with a Rotary.
Your also assuming most people are like me and you and have a bit of common sense (no dis-respect to the OP!!) :)
Theres an orbital sander in my garage that looks very similar to those machine polishers, does the same job I suppose... If I got some polishing pads and a spare panel to practise on, does anyone reckon the orbital will produce the same result as these?
http://i4detailing.co.uk/acatalog/Kestrel_DAS-6_Menz_Kit_1_1.html
Would this be any good, as I am in the need of a polisher too.
I know I will prob need to buy more polishes and pads right?
Ive got all the clay, lube, MF's, 3M tape and some wax.
EDIT: As thats not in stock...
http://www.cleanyourcar.co.uk/polis...as-6-pro-sonus-and-menzerna-kit/prod_677.html
http://www.cleanyourcar.co.uk/polis...ion-polisher-menzerna-intro-kit/prod_720.html
Is there much difference between the DAS-6 and the Pro?
all the kits will get you started for correction, but you need to prep the panel before machining it. Wash, de tar, clay, plenty of MF clothes for wiping down. after machining the panel should be cleaned or wiped down, then you start on cleansers / glazes / sealants / waxes etc etc etc.
As said all this will have already been asked on the 1st couple of pages of the car detailing sub section.
