electric window conversion??
  Clio mk1 1.2
i have a 1.2 mk1 clio and it has manual windows i am in the process of doin doorbuilds and want to convert the windows to manual, how easy would it be to convert both driver and passenger windows
if there is an exsiting loom in the car it should be a sinch. a know in my fiesta SI i had the loom and put electic windows and central locking in that.
you can get a kit for manual windows to turn them into electric 1's..
its basically a motor that turns th existing cog
what you need to do is to just add the electric window regulator and the motors. Its a one piece unit. and then all you need is a set of switches. in terms of wiring you only need ground wires and then power wires from a fused connection thats live on the ignition. Would advise using a relay. but i its easy.
Have a go!
