Clio 1.5 dci 2002
Hi everyone have a little issue with my lights
In a nutshell the headlight on r/h doesn't work,
tried changing bulb with no joy,
However the r/h indicator remains on like a headlight instead if that makes sense,
When the headlights are off the indicators work as they should however when the headlights are on the r/h side indicators flash fast
I'm at a loose end now
I would assume the indicator relay is fine as the indicators flash fine when headlights are off,
Both side lights come on and off when the steering wheel is turned left and right
I'm starting to think it could be the steering wheel stalk connectors or I could be wrong but on the hope someone knows if this is a common problem or it could be something someone has had a issue with before
Probably a bad earth somewhere but I'm not too great at electrics but if I had a idea what I'm looking for id be happy to fix it
Thanks in advance for any help with this guys hope your all having a good day
