Electrical issues (ph1 172 conversion)
Car  1.2 daily +172 ph1
Hi all had a conversion going on with a ph2 non sport tack car had a ph1 172 engine put into it with full wiring loom engine, dash , rear, and also door looms but have not connected up drivers side yet.
Engine is all up and runing and only a though things holding it bk.
Had to re-wire ph2 front headlights to match up to ph1 loom and all work perfectly.
But with rear light things go crazy u turn side lights on and both Rear indicators come on to very dim with other things coming to the dash showing the indicator bulbs very dim on the dash.
I am running ph1 loom to ph2 rear light could this be a problem and who could I talk to for help on this thanks ?
Have a look in the guides section and it will tell you how to wire a ph1 to ph2 rear lights. All you need is a small flat screwdriver
