Clio 182, porsche944
				Hi guys, have a huge issue I could do with some help....
My clio 182 2004, was driving as normal, went to fire her up, starter motor refused to crank the engine.
Aquired a new starter motor, and went to fit it, when disconnected from the engine It whirred a little, checked all the relays and found one a bit corroded, cleaned the corrosion off and the starter motors power increased, great I thought... Found the issue, re_connected it up turned the key, nothing...(then got stuck abroad with work for 5 months due to covid)
I got home and I was gonna take it to a garage, thinking I'll bump start it and hope I don't stall on the way to the garage.
Tried tow starting it with a van, fired up but kept very loudly back firing and spluttering and then just died, so now I'm thinking I also have a dead battery......
Bought a new battery.... Connected it up, went to hook up the tow rope again to bump start, and luckily noticed smoke coming from the engine bay on the left, alot of it, and getting worse, the key wasn't even in the ignition.
Any help would be appreciated, I'm new here and I know I haven't earnt it as such, but Ive been following this forum for a while and you all seem like helpful guys
