electrical system when running sound system
Car  BMW M135I
Just wondered what battery and alternator people use when running a sound system without moving the battery into the boot or what they consider good setups.
Also where did you get the alternator done/from?
Are you serious ???
Each individual system has different requirements based on a multitude of variables, how can you expect someone to write an essay covering all variables just because you don't know what your doing....
The way forward is for you to include all relevant information on your proposed system, including details on how you plan to use it....Then someone can give you advice based on fact, rather than guesswork based on other peoples systems....
All im basically asking is for an aftermarket battery people use in the clio when using a sound system that fits in the place of the original
and
if anyone has got a different alternator to help the power supply (different or recond'
and
Like wallop said, what are u planning on running off it???
Youve just simply re-worded and shortened what u put in ur first post!!
If ur running just a simple amplifier and a sub then leave what uve got cos it will more than likely be fine.
An optima battery would be an upgrade from the original renault item
got a start, does the optima fit straight into orignal clio battery place because any others ive seen (not on here) seem to run from the boot because they are bigger.
An im thinking of running 3 hifonics amps off it, 1206d's i think they are with 3 hifonic brutus
