Electronic Fault Warning Light
  Black 172, Transit!!
Hi all, Nubee in need of your help for my 172...
I was driving home this morning and the Electronic Fault Warning light came on and I lost drive ie push down on accelerator and nothing. Pulled over, turned off the engine and re started the car light went out and I continued on my way. The light came on again as I arrived home but I was still able to drive around.
Any suggestions before I resort to taking it to the garage.
Thanks J
  172ph2
I'd say check the wires, get someone to rev it a bit while you give the throttle body wires a wiggle, see if you can manually induce the problem.
Failing that, get your fault codes read. Might help narrow things down a bit.
