Hi, i need some help figuring out a problem.
Some time ago it started with the pedal on the breaks only, sometimes it would light up the fog light on the dashboard, but it would be a split second and gone.
Recently it happens anytime a light in the rear headlights comes on, it also flicks the tail light when it flicks the dashboard, be it braking, reversing or signaling.
I can't see any broken cable on each headlight housing connection, if i remove both rear headlights i can brake/reverse/signal and it won't flick anything on the dashboard... i thought of fuses but wouldn't that just blow and not cause a short?
Anyone got an idea before i buy a new headlight housing to test?
