A
ashy_gtt
Hello,
Can you help me again... I've have spoken to reno today about the parts that I need for my engine which are:
Head Gasket.
Cam Shaft Seals.
Cam shaft blanking caps.
Jointing paste for Rocker cover to head and oil seperator to rocker cover.
Sump seal (also is a sealant used on the sump or just the rubber seal?).
Cam Belt.
Cam Belt Tensioner.
Cam belt folower (the bearing / pulley wheel)
Head Bolts.
Oil Filter.
Water pump gasket.
Now ive found most of the part numbers from reno but for the cam belt and tensioners they need the actual engine or chassis number... the only numbers I can find on the block itself are on a white ticket with a barcode on it which are:
F4R D 736
7701716334
C 023417
Can anyone help / provide me with a chassis number or engine number i could use??
Cheers Ashy
Head Gasket.
Cam Shaft Seals.
Cam Belt.
Cam Belt Tensioner.
Head Bolts.
Oil Filter.
Water pump gasket.
F4R D 736
7701716334
C 023417
Cheers Ashy
