Engine Cuts Out on Start Up????
Am having abit of a problem with my ph1 172, a couple of time over the past few week it dies as soon as I start it, it splutters as if its trying to get going and just dies, now I know Clios take a few sec to switch over with the fuel pump and it was very hot days this happen so I just presumed that it was the heat affecting it, but twice this week, not overly warm it has happened, should I be concerned???
Nathan
  Works...kind of...
First port of call would be coolant temp sensor. Cheap and easy diy replacement.
Do a search on here, been mentioned many times.
  V6 Exige, GTR R35
could be a number of things:
coolant temp sensor as already mentioned
coil pack damp - plugs on spark plugs damp and need dried out - spray with wd40
or tdc sensor located ontop of gearbox - might be dirty and needs wiped.
i'd start off with them and see how you get on
  Ph1
My idle / start up is crap in this warm weather too. Must be a Clio thing? lol
Another one to check maybe, idle control valve. Might be worth a jet with carb cleaner if its not been done before
  clio sport 172
Nathan
i get the same prob start it first time when cold it dies then try again it starts fine.
  172 Silver Cup
I have 2 keys and it does this with one and is totaly fine with the other. I am putting it down to the imoboliser. Guess in your case it wouldnt be this as u r using the same key everytime??
Ive tried both keys and it happens with both, to be honest the common factor is the warm weather, it starts fine on ok days n at night just when its in the 20s and its been sitting outside work all day it sumtimes dies.
  RB 182 & Lotus Evora
mine is doing this right now too. If u find the issue let me know. I think the last concensus was it was the TDC. Although i took mine out and cleaned it but it didnt fix it. They now replace these and use new wiring loom for it...
  Clio MK 4
i'm having exact same problem. Only in mornings though. First time i start it it starts and splutters and dies unless i rev it to get it going. Otherwise second time is fine.
  Megane 225
Mine s doing the same thing 2! Thought there was something wrong with it, but obviously it's just a s**t renault! Lol! It's ok when the weather is not so warm!
