Engine Idleing
Car  1995 Clio RSi 1.8
Evening all,
As stated over here somewhere <----- I own a 1995 1.8 Rsi, which I bought recently.
The other day just after I started my journey to work, I stopped at a junction waiting for my gap to pull out, and I notice that my rev counter was going up and down around the 1 mark ( or 1000 or whatever the hell it is :)) so much that it was nearly stalling then it would bounce back up higher and drop again etc etc. I mean its all fine and it runs ok, im just sure it shouldnt do that. At first I thought it might be the automatic choke, and I havent looked into it yet, but I just thought I would ask your thoughts on the problem first.
Cheers, and thanks in advance for any help.
have a go at cleaning the throtle body out can get dirty and make it idle funny . Sure the other boys will tell you what it is
Alan
Ok I cleaned out the idle control valve and the car is idleing much better now. But it still is a bit doggy. Inside the icv it was still a bit stiff, just wondering is it safe to spary some wd40 inside to loosen it up a bit better?
Also have the same problem even though i have changed the idle control valve :s
anything else it could be?
Rich.
main problems are icv's and throttle bodies..
check your plugs and leads too, check air filter isn't clogged.
