Engine Lights Came On.
Sam
North East
Hi guys.
Just turned my car on after leaving the docs and noticed the engine light in the bottom right was on. Drove the 2 minute journey home and parked her up. I turned it back on and it still stays there. The car starts first time and drove fine coming home.
I plugged my RS Tuner in and got these faults.
I know all the airbag ones are from the Recaros (I think) and the Throttle control limit says 'Not a fault'.
What are the other two ? How can i fix these and will they have caused the engine light to come on ???
Any help is appreciated.
Sam!
  172/1.2/E30
O2 sensor fault triggered the engine light i guess. 2nd fault is related to the brake pedal switch afaik. Could be a faulty O2 sensor or damaged wiring.
Sam
North East
Just to add, ive checked the oil on the dashboard and it has 4 bars so theres plenty in there!
Sam
North East
Ollie, will it be ok to drive with an 02 sensor fault ? Are they hard to replace ? Where are they located ?
  SEAT Ibiza SC FR
Shouldn't be a massive issue, it'll just run crap.
Sounds like front Lambda sensor to me... (I may be wrong, someone will probably be over soon to correct me). If it is, it isn't a big job, but it's underneath the car.
Sam
North East
Ahhh. So the 02 sensor is a lamba sensor ?? Well, my exhaust is blowing like a f*cking jet fan at the moment. Reckon this could be messing somit up ?
Sam
  Black 172
My engine light comes on for a few hours or days then goes out. I bought the car knowing this and fully expected to have to change the O2 sensor, but I put it in to MoT with a bottle of Wynn's Emissions Reducer after a fairly hard drive and it made it through the emissions test (albeit just; the lambda reading was on the limit). Fuel economy and power are fine but I'll get round to changing it soonish, but there's no rush.
I looked under the car and TBH the access to the O2 sensor didn't seem as bad as what I'd read on the forums, looked quite straightforward really but I expect I won't be saying that when I come to do it.
Sam
North East
Update.
Ive went and had my exhaust resealed and new clamps put on it. Sounds really quiet now compared and i can already see the better MPG. Feels a tad more nippier to.
How do i use the RS Tuner to turn the dashboard light off?
Sam!
Sam
North East
Update.
Sam!
Anyone ?? Is it possible ??
steve32c
  200T
Plug it in and select clear all faults I think the brake one stays for some reason and probably the air bag faults on yours but hopefully once cleared it should go out, unless some one else knows a different way
Sam
North East
Thanks. Will try this tomorrow. :)
