Engine management flashing with misfire
  Civic Type R
Hi
Did an oil change yesterday. Driving the car today and i started to get a really bad misfire, followed by the engine management light flashing. Plugged the RS tuner in and no fault codes stored. Does anyone have any idea what this could be, have checked leads / plugs etc and everything seems right?? Theres a really bad smell of petrol when its running, coming from the exhaust but smells like pure petrol,
Any suggestions would be appreciated, cant drive it how it is!
cheers
Wayne
Da
  Less
Could be a few things - coilpack/plugs/leads/O2 sensor.
Any further lights on the dash?
  Civic Type R
No other lights , when it's first started there are no lights at all - engine management starts flashing after couple of minutes - just plugged rs tuner in again and it had a fault stored - rear 02 heater fault?? Anyone have any ideas what this is?
maynard
  ph2 172 track car
rear lambda lensor from the looks of that description.
that particular lambda is classed as the diagnostic lambda sensor, and costs approx £60 for a bosch one from a motor factors.
  Civic Type R
Not sure if its coming up with that becuase its decatted. Its now also coming up with code df003 intake air tempreture sensor?
  Civic Type R
also, when it was cold this morning it ran perfect for about 4-5 mins until it warmed up, then it ran like a bag of s**t again
