Engine management Lambda issues
  Clio 1.2
My 2001 1.2 Clio has been repeatedly to the garage becasue the engine management light is on. When cleared the light stays off for two engine starts then comes back up again with faults on the Lambda sensor (new) and the air conditioning (I do not have air con). The auto electrician couldn't find any circuit faults. I am at the end of my tether!!! Please help.
The ECU on your car in in the center of the engine bay at the back of the engine as such check the metal cover ontop of it and all the fuses and relays near the battery
I'm having the same problems. My light has come on for all sorts of things from coils to breaklight sensor. the last time it came up with 2 speed fan (for air con) ,my car doesn't have air con. that was a month ago, but it has come on again and i,m too embarassed to back to the garage again.
