Engine Management light..
  Civic Type R FN2
the past few months my engine management light has been flashing every now and again, but it usually stops after a few minutes, but this morning it came on and stayed. Then coming home from work I was on the dual carrigeway, everything was fine untill I put it into 5th gear then it misfired a few times.
when it comes to this kind of stuff of a car I'm hopeless! so any help would be appreciated.
  clio 172
just a guess but try tdc sensor 22 pound from gsf common fault if i remmember rightly hope this helps
phil
  Civic Type R FN2
the misfiring has stopped which is good, won't be able to get the car booked in till Friday though, so I'll see how that goes.
thanks.
