Engine management light
Car  Iceberg 172
Have recently acquired a solid EML on the clio 172.
The car has a lumpy idle, pops and bangs alot at high revs and has blue smoke.
This has only just happened recently. (1 week)
Just as a quick check list (dont have a code reader atm)
- Both lambda sensors?
- Spark plug
- Ht leads
- Coilpack
Are these the more likely problems to why the car is running rough.
(the car has had a remap by ktec)
thanks
Just resets lugged a code reader and reset it and the light has gone, with no blue smoke etc.. Flagged up with a lambda sensor. Could just be minor fault. Will post again if it flags up again.
Is the blue smoke from exhaust or is oil dripping onto manifold as a result of possible rocker cover leak?
