engine management system
Car  Static Low
does anyone know much about it ??
my toxic fume monitoring light was coming on the other day.. then it went away.. and yesterday it was flashing and my car went funny !
anyone know much about this s**t ?? cause its really really pissin me off !
i hear i havent to get my whole system checked out and im sure renault will charge me lots of money i dont have :(
thanks
Im sorry mate i dont even know what a decat is.
If its any sort of mod, my car is just standard at the moment !
52plate dynamique !
.. it started flashing yesterday then my car stated going slow.. so i pulled over.. restarted the engine.. and then it was ok.. but it seems to jerk now and again !
52plate dynamique !
thats definitely the lambda sensor by sounds of it. When i unplugged mine from my chip it started kangarooing.
yeah it kangaroos slightly when changing gear !
its really doing my tits in mate !
so whats the lambda sensor then ??
any info on it ?
cheers
:( my dad will fuckin eat me !
..haha
alrite i nat to hear from this guy :) id really appreciate it ! !
thanks for the help guys
Bets get it plugged into a CLip computer also check your spark plugs and coil pack might be bust.
Check the wiring at the back of the engine there a metal clip/box type thing the wires under it short often and cause problems.
I have had problems with this warning light flashing on my Megane with the symptons you describe. The problem was a failure with the Pencil Coil that plugs in to the top of each cylinder. I had two failures with these and each time I called out the AA and they replaced them. They cost about £40 each. The man from the AA did advise me to get the plugs checked as well though. I hope this helps.
