Pearl Black 172
Sure?, easy / cheap to fix?
release bearing deffo. will get worse untill it colapses then gets stuck in gear. not sure on clio parts but probs a 50 or 60 quid part, if a garage does it, probs looking at a bill in excess of a grand with labour. Get the tool box and engine lift out
You can't afford £60?
Realistically, there's no point in having this changed without the clutch, at all.
So:
Full three piece clutch kit (including release bearing) £130.
Fitting: Free if you can fit a clutch yourself (about a 5-7 hour job on the floor)
Total cost from a mechanic is between £500-800
