Engine number???where
Car  16v & FRST
Where is the engine number on a clio 16v??? can someone show me in a picture pointing to the area, many thanks
:D
at the front of the engine, just to the left of the oil filter, good luck with trying to work it out!
Alternatively pm me you reg number and Ile look it up on renault net for you
under the inlet manifold on the block, throttle body side, prob easiest way to see it is removing the bonnet, the slam pannel and moving rad slightly... should see it that way... if not remove the rad
Well if it's an F7P it'll be 1764cc which is what should be in a Valver.
An F7R is 1998cc and has a white dot on the dipstick.
plattsy have you got a spare f16 spark plug cover kickin about?cheers lad
