engine removal question
I'm currently removing my engine (172 cup).
Where is the best place to disconnect the power steering pipes?
I figured it would be on the rack but it doesn't look very nice down there so I was thinking I could disconnect them at the pump and hold the pipes out of the way - seeing as they have flexi hoses over the gearbox.
Why even disconnect it? I leave the pump and joints intact and simply pull it of the block accessory mount then leave the pump floating in the bay and then lift the lump clear... Works with A/C to (if you have it)
Mick
