Engine starter problem HELP!!!!!
RB182CUP-FF
  2118's RB 182 CUP
hi i been using my 182 all day just when't to start it and the starter motor would't engage not sure if this is the problem or not, also when i when't to lock the car with key fob that would't work either. when i turn the ignition on there's a noise coming from the dash. can any 1 help me with this or has any 1 come across this problem before???
cheers Lee
RB182CUP-FF
  2118's RB 182 CUP
yeh car bump started fine just been back out there again turning the ignition on and leaving it on there was a buzzing noise coming from engine bay. also trying to lock it back up it would't lock and the alarm was making all sorts of buzzing noises
RB182CUP-FF
  2118's RB 182 CUP
bump started the car and toke it for a drive and it drives fine but soon as i turn it off its back to square 1 some 1 plz help:mad:
G
Gregor11
while turning the key get someone to give the starter a tap, in case its sticking. have you checked for power down to the starter? have you checked the alternator output while its running?
G
Gregor11
if memory serves, its a pig to get to, its at the back of the engine
  bg182ff
I've had a similar problem today car was running fine turned the ignition off 2min later went to start it and nothing the fan belt moved an inch and stopped :/ bump started it and it's now been fine all day :/ guessing it's having a French day lmao :)
RB182CUP-FF
  2118's RB 182 CUP
some 1 has told me it could if key fob battery is dieing will this affect the starting of the car????
