Engine starter problem HELP!!!!!
RB182CUP-FF
Car  2118's RB 182 CUP
hi i been using my 182 all day just when't to start it and the starter motor would't engage not sure if this is the problem or not, also when i when't to lock the car with key fob that would't work either. when i turn the ignition on there's a noise coming from the dash. can any 1 help me with this or has any 1 come across this problem before???
cheers Lee
yeh car bump started fine just been back out there again turning the ignition on and leaving it on there was a buzzing noise coming from engine bay. also trying to lock it back up it would't lock and the alarm was making all sorts of buzzing noises
bump started the car and toke it for a drive and it drives fine but soon as i turn it off its back to square 1 some 1 plz help:mad:
while turning the key get someone to give the starter a tap, in case its sticking. have you checked for power down to the starter? have you checked the alternator output while its running?
if memory serves, its a pig to get to, its at the back of the engine
I've had a similar problem today car was running fine turned the ignition off 2min later went to start it and nothing the fan belt moved an inch and stopped :/ bump started it and it's now been fine all day :/ guessing it's having a French day lmao :)
some 1 has told me it could if key fob battery is dieing will this affect the starting of the car????
