Engine warning light after changing plugs and map sensor
  Megane 225 Trophy
My cars been off road a few days, changed plugs and map sensor
Now although running fine the engine warning light is on
Any ideas
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
Did you run it with the MAP sensor (or any other sensor) unplugged? If so it will have logged a fault code... sometimes, the light will go off after 3 cycles of successful startups. Failing that it'll need plugging in to destroy them and turn the light off.
Mick
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
I promise you it will have... it might not have triggered the MIL but a code would have been generated
  172 cup- suzu rf600r
it might be possible to clear it by disconnecting the batter for half an hour? i put the question mark because this is a fairly unfounded guess mind ...
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
On some vehicles yes... I know this works on the Astra G as i've done it myself but I don't think it works with EM faults on the Clio II
  Mk5 golf gti
do as mick says, after a few times starting if the problem isnt there it should go out
it wont be an mot failiure unless the EML has come on due to emissions
