no worries mate.
with the valves seats you should get them cut with a 30 degree top cut a 45 deg middle cut and 70 deg bottom cut.
Inlet ports should be a minimum of 75% of the valve diameter for fast road and 80-90% for full race, but low rpm running will be very rough, especially with a wild cam. This is down to the low airspeed at low rpm and fuel suspension in the airstream becomes difficult an you may get pools of fuel at bends. Exhuats ports should be minimum of 80% of the valve diameter, and larger doesnt matter.
manifolds should be matched to the ports in the head. The finish in the inlet should be done with a smooth 80 grit flap wheel.
Exhaust manifold should be bored out as much as possible, and polished if you like....a 4-2-1 manifold is better though, with the longest primary headers you can get.
The ultimte problem will be fuelling. The stick SPI system is poo, and you can upgrade to the 1.8l laguna SPI system....but if you want the best...find a set of twin webber 40dcoes with 36mm venturis. and see if any manifolds fit. If not, get a dcoe manifolds, and cut the bottom mounting points off, tig weld this to the bottom of your existing RT manifold.
If you would like an futher help, email me @ Ching@iamwasted.com.
if you can manage it, cut the valve spring recesses deeper and fit double springs and larger inlet valves...
