Perhaps uprated cams help provide extra flow which an enhanced body would make use of?
How do you think you extract 270bhp from a 2.0 engine?
I could tell you, but your'e not likely to believe me.
I pm'd a lad on here a year back who had a enlarged Jenvey TB fitted and he claimed it made bugger all difference.
Going by the fact tuners arnt exactly falling over themselfs to promote a larger TB on a 172/182 this would certainly match up to the reports of it not worth messing about with
i have a larger jenvey tb, and along with other mods it DOES make a noticable difference to the drivability of the car - imo of course
please. someone. actually do the exercise.
they have...people chose to believe BenR and never question it though...
maybe I should post up MY AWT experience?
If I said yes you will find fault and if I said no you will find fault.
How did you get on at Devil the Torque of?
Its been done.
"Similarly, in an experiment to curb the power of 270 BHP touring car engines, we reduced the size of the single throttle body to less than 44mm (1520 sq mm) before there was any noticeable reduction: a 75mm body has three times the flow."
If a 44mm opening provides enough air flow into a 2.0NA engine to produce 270bhp why do you need to enlarge the standard TB on a 200bhp engine to produce more power?
omg i'm so bored.
F3, 235bhp on a 26mm hole...............go figure.
Is it the size of the hole, or how well you use it?
If a bigger TB is all thats needed to make whopping power, why wasnt the factory item made 70mm?............
Infact you've lost me.........who builds what for the clios? Tell them what they need to hear in accordance to what they are selling? Good thing i'm not selling anything along the lines of such things, or maybe i need to be?
Some of us understand.
A bigger TB will give "better" throttle response at small openings. But at higher throttle openings its not the TB that restricting the airflow, its other things in the intake tract. So you don't change your peak airflow/power by increasing the size of the TB, you just get more horsepower at small throttle opening, and less additional horsepower by opening the throttle further. Which makes the car jerkier to drive in traffic. And if you did want that you could achieve just as easily with a cable-operated TB by changing the leverage, or on an electronic throttle with one of those electronics boxes that senses you pushing hard on the accelerator and opens the butterfly faster.
