Audi rs3/Clio 172cup
Hi
Recently fitted an epas column, eBay controller and quick rack.
Everything is wired up to how the instructions state.
When I turned the car on the epas worked but the resistance adjuster there was either no assistance or full assistance.
Seeing as I’ve never drive a Clio with this conversation I thought it was normal.
Did I few road miles. All seemed fine until I took the rally car on track.
When under braking I get no epas at all. Then in certain tight corners epas would come and go. Had a very big moment going through a chicane flat out and epas decided not to work mid way through.
The car also suffered with a misfire, like the epas was drawing power meaning the injectors weren’t working.
I’ve read a post before with a similar issue under braking and was wondering if any one knows what it was before I take everything off and test it all
