Dacia Logan
Hi I am new to this forum and some purists might think why am I posting this on here but was hoping that someone might be able to advise on my 1.4 inj Clio engined Dacia Logan 2005 (french registered). It has failed the french equivalent of the MOT badly. I have since taken it to different Renault garages and they said that the Lambda sensors were broken. I had both replaced and then retested it. It failed again. I was then told by Renault that the Cat was probably dead and needed replacing. So I had that replaced and still it failed. Both times I gave the car a good run and got the cat nice and hot before the test. Doing some research on the web, it has been mentioned that the injectors in my clio 1.4mpi engine could be replaced and this might sort the problem- is this worth trying next? Other problems could include ECU? Any help/ suggestions appreciated as this is driving me nuts and costing me alot of time and money!
