ESP LIGHT HELP
Car  clio
just popped to the shop and just have the serv light come on and the traction control light come on and they seem to be on all the time now is there a simple way of truning the traction/esp off ?
Yup there's a guide in the correct section, just SERV + ESP means it's coming on too soon so will need pulling out slightly.
http://www.cliosport.net/forum/show...w-to-alter-brake-pedal-switch&highlight=brake
To be honest you don't even have to bother pulling the actual switch out from where it is, just push the brake away and you can pull or push in the end of it with your thumb and forefinger. If you're getting two lights, pull it out, if you're getting three lights, push it in. Do it at night or with someone behind the car so you can see when the brakes lights come on. For me the solution was to pull it out one more click after they 'instantly' came on from a light brake pedal touch.
