Ethernet Cable Routing
Tom
Car  i3
Hi, i'm quite handy with most things but this has got me reaching for the keyboard.
In my flat my BT master socket is in a utility cupboard and its separated from the TV/XBOX/ATV by two walls.
My current set up is Router, Homeplug, Homeplug, Switch and then ethernet to all the respective items that need it but this is a slow set up. So i've ordered some flat ethernet and was going to just run it under the carpet until i started thinking about the unused phone cabling in the flat;
Could i just tie the new cabling and pull it through, change the faceplate and wammo mega neatness, or shall i stop being ambitious and just run it under the carpet?
If the first option is remotely possible, how do i do it? Literally just tie it on at one end and pull?
I've got some cheap ones, they aren't great. 30mb/s tops.
All the ones ive seen have 10/100 ports so the max you'll get is what 60mb/s?
Yeah theres a Linux box running plex in there thats got all my content on.
Currently its not a big issue, but my internet is going from ADSL to Infinity 2 at the end of the week and i'd like to make use of the potential 70mb increase.
Upgrading the HP's is a easy solution, but its still not as quick as cable no matter what i do.
