exhaust hangs low
Car  MK2 PH2 & E46 330
my exhaust hangs a bit low. its a bit annoying.
ive had garages look at it then rehang it while they did other work. but it looks all the same to me. the only thing thats new are the hanging points.
its sagging in the middle ____ here (red bit)
\__
and its low at the back where it should really be flush with the bumper i think. (ill try get some pictures)
whats needed to be done to pull it higher you think?
anyone? sorry the diagram i drew didnt seem to work... its just the L bend in the pipes im on about
try packing out the exhaust mount with some silicone tubing secured with cable ties. Put a small piece in the left, bottom and right parts of the exhaust mount rubber spider.
This will raise the ehaust, and prevent it from bouncing around over bumps.
ill have another look with that in mind. it seems theres just no mount where the exhaust hangs low. its always been like that. maybe just a thing with mk1s?
oh my bad, i didnt read it properly.
didnt see it was a Mk1... and i also didnt notice its the center section thats hanging.
ah well, i'll get my coat.
my rt's hangs down a bit and my valvers did to till had a ss fitted to it .see mk1 clios all the time with the L part hanging low.get garage to weld another bracket on the L part .mate did it ,solved his.
