Phill90 Car None May 21, 2009 #1 If this has cracks in or is not securly tight to the cat or whatever it connects to What problems will you face or what can problems can it cause etc etc
Phill90 Car None May 21, 2009 #3 Ive got 2 decent cracks in mine and it does not sit flush at the bottom wasnt sure if this was going to be a problem looks like ill need to sort it
jack_davey Car Black Gold Trophy May 21, 2009 #4 I'd try welding it up as they are pretty expensive to replace.
Phill90 Car None May 21, 2009 #5 Found a couple on ebay for around the £25 mark, and my mechanic will fit it cheap so cant see it being more than £75 if that sounds about right
