I got an exhaust mount for £21.76 from renault... btw, the new ehaust your putting on is most likely to be heavier than the original exhaust so it might be worth modifying your new mount...heres an example...
my mount is actually modded with inch long pieces of hose pipe, with a slightly thinner silicon pipe pushed inside the hose, then a section of copper pipe wedged inside that...not really going to drop with the copper pipe in it.
especially if you cable tie the hose pieces in place under the hangar of the exhaust.
