External Hard Drive USB Powerd
Wow, maybe Toshiba do then Heheh. :o
Very very rare - normally laptop manufacturers just use WD, Hitachi, Seagate etc.. for their drives as it's not worth their bothering.
Anyway, Go buy a Seagate or something ;) :P
Daz said:
Well.. I'm sure they don't make the drive.
Maybe they started?
Let's just argee that im right :D ;)
To get this thread back on track :-)
So what external hard drives do you friendly CS Fokes recommend.
yea, I'm wrong.. just looked. Heh :( Sorry.
Anyway, after a bit of googling I think they are OK?
Hope so, I just brought it :)
(I remember you saying you had a carputer before)
Just wondering what keyboard you used?
Because the one i have (wireless,With joystick mouse) seems to have 'Broke' and only works about 2feet from the transmitter.
It's in a box in my loft now :(
Not been used since I removed it all from the car a few years back.
I would of took a VGA monitor if i new how s**t RCA was when i 1st started my project, But now i have 4 RCA(Screens) so a VGA would be hard to intergreat into the proJect now.
Rob_887 said:
I would of took a VGA monitor if i new how sh*t RCA was when i 1st started my project, But now i have 4 RCA(Screens) so a VGA would be hard to intergreat into the proJect now.
Would it?
You could still just have a VGA in the front.. and use the rest elsewhere..
Daz said:
Would it?
Guess it could be done, But i use the front for Xbox/Free View Box/Pc/Rear View Cam/Front cam/ And there not VGA :-) and i cant get in the back when i want to play. Also i have soldered all the RCA's to a "Switch block".
I've just got a 300gb Maxtor(Seagate lol) external HD. Its ICP/IP Network ready so uses Ethernet instead of USB, Its conected to my Wireless Router so my 2 Desktops and Laptop can share it. It also has a couple of USB ports on the back so you can plug a Printer into it and share that on the network as well..
£90 from Staples.. Clearance.
Whats it powerd by
Sorry mate, didn't see that bit..
I'd go for a Sandisk Firelite then, iirc they go upto about 80gb and powered by USB.
Bigger is better :) But also has to be fast enough to steam movies.
I have found a 120GB powered by USB but thats the biggest i can find any where, That is powered by USB.
Do you not have any firewire? You can get powered FW drives higher than USB.
Largest USB powered is 160GB by Seagate.
Sorry its Smartdisk Firelite.. not sandisk.
I'm sure you know but make sure the 120gb is 7200rpm and not 4800..
The Firelites are 7200..
Indeed i have firewire.
5400 RPM(High Speed)
Rapid 480MB/sec Transfer Rate
That sounds interesting.
Is there any chance you could knock up a system diagram for me. I'm looking for ideas in this department.
I don't know if this help, It's my planing diagram, It's really just for me to understand, If there is a part of it thats confusing you tell me and i will explain.
Only other one i have is this, And if this dont confuse you :-) I dont no what will lol.
If you need any part of it explaing more just ask :-)
Missed out all the 12V wires go to the roof panel where there are switchs
I doubt they'd get power from the hub?
Normally, you have to plug two USB plugs into the computer if they are powered.. Hubs tend not to have enough power, but I could be wrong.. (unless it's powered which then you need to plug in! :p)
Crikey!!
I knew i should of gone for a career as an auto electrician!!
gazzrenn said:
Crikey!!
:-) Come on then, What plans have you got for your car.
Daz ( I just noticed the HUB has a plug for power ;) )
