Re: f**kING BEARING
Yeah Maxiboy on C16V said just you can properly still use it anyway, I think I will.
you've f**ked the new disc there?
lol just the bearing, was going to get a new one pressed in as it came without a bearing anyway.
as odd as it sounds you have marked or have s**t on your stub axle, but you have pulled the new disc off! why?
Started to put disc on, bit stiff so pulled it back off and it left that! Didn't want to force it as last time I put a rear disc on it just slid on nicely!
Tigger said:
The rear right (same as above it would appear) was the devil himself I think - set us back hours trying everything to get it off and pi**ed us right off!
This is the rear right for me too, took me 25 minutes before I worked out that whacking the back with a hammer was moving it, then 10 minutes of that and the old one came off! Never had that before, normally they just slide off!
what are the symtoms of worn bearing, how wud I know if bearings are gone.
Loud hum, constant if on rear bearing, changes depending on steering if on the front. Unmissible, once you have heard one its very easy to diagnose!
