F4R Cam seals
  Sell me your 197
Hey blokes,
Does anyone have a diagram of which seals go where in relation to the cams? I have many seals but the diagrams I have aren't clear enough, I can't tell which seals go where.
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
Not got any diGrams myself i'm afraid but the camshaft seals (timing end) are the same outside diameter but the internal diameters differ; smaller ID is the exhaust cam, larger ID is the inlet/dephaser cam. Clutch end seals are simple as there are two obvious sizes. Dephaser solenoid seal is also unique in its size.
When seating the new seals there outer face should be flush with the outer face of the boss that you're fitting them to. leave them sitting proud or too far in and they wont seal correctly.
Mick
  Sell me your 197
Correct me if i'm wrong:
They have given me 2 "2 tone" and 2 "tan" seals as well as a smaller one. Only 1 2 tone seal pictured
2 tone seal = Exhaust pully end
tan seal = dephaser pully end
smaller seal = ????
"Caps" = clutch end
What is the smaller seal for, and have they doubled up on cam seals for me or do the other two go somewhere?
  Lionel Richie
thats for the VVT solenoid, as mick says make sure when you fit them they're flush with the outer face of the head, will look weird if you're not use to it, but its correct
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
Left is for the dephaser/vvc solenoid on the top cover as Fred pointed out above.
Mick
