Register a free account today to become a member! Once signed in, you'll be able to participate on this site by adding your own topics and posts, as well as connect with other members through your own private inbox!
Does anyone have a diagram of which seals go where in relation to the cams? I have many seals but the diagrams I have aren't clear enough, I can't tell which seals go where.
Not got any diGrams myself i'm afraid but the camshaft seals (timing end) are the same outside diameter but the internal diameters differ; smaller ID is the exhaust cam, larger ID is the inlet/dephaser cam. Clutch end seals are simple as there are two obvious sizes. Dephaser solenoid seal is also unique in its size.
When seating the new seals there outer face should be flush with the outer face of the boss that you're fitting them to. leave them sitting proud or too far in and they wont seal correctly.
thats for the VVT solenoid, as mick says make sure when you fit them they're flush with the outer face of the head, will look weird if you're not use to it, but its correct
