Failed MOT
Car  WANTED Arctic 182
Hello peeps
My 182 just failed :(
It failed on 'nearside front brake hose twisted'
Is that as simple as it sounds? Easy fix?
Also on rear brake pads. My step dad seems to think that rear pads are a lot harder to change than the fronts and that I may need a special tool. Is that true?
I thought It would fail on one headlight washer not working and one windscreen washer not working!
Cheers in advance
if its just rear pads , easier then fronts, if its discs too then a little harder
get a pic of the hose line , cant see how it would go like that, but wouldnt think its a hard fix
twisted hose will be some knob head who fit the last lot of brakes, its either remove caliper and twist it around to correct position or unscrew hose and repostion.
Rear pads dont take long, no special tools needed.
So I was right in thinking changing rear pads is exactly the same as doing the fronts, difficulty wise. My step dad seems to think it will be harder because of the handbrake?
I'll get photos up of the hose soon
the hose twisted will more then likely be a case of undoing two calliper bolts, untwisting then rebolting. 20 mins job!
