Fan blowers stopped working
Car  RS Clio 182
I did a quick search on this and could only find something a few years back - just wanted to see if i could get some help.
I turned on the demister the other day,and after about 30 seconds it cut out,and none of the blowers are working,the climate control unit is still working and so is the heat,but the fans have died. i can hear a whirring noise where i think the fans are trying to work. Is this likely to be a blown fuse? I read somewhere that water damage can cause this - i had a hand & jet car wash the other day,could this be the cause?
heater resistor pack
bridge the ports 1 & 5 with a piece of wire in the connector
if they work they will be flat out.... you need to buy a new resistor sensor or send yours off
ive just had mine done and works fine
