Fancy some gauges for Oil Temp/Pressure
Car  Track 172 Cup
As title really I fancy some gauges for the oil temp and pressure for my 172 track car and also a guide as to how to fit them (unless its simple) . I like the SPA digital gauge as you only really need the one and it looks tidy, is it just a case of oil filter off fit the sandwich plate and sensors refit oil filter and run a wire to the gauge? Or same if you use the sump plug adaptor?
Cheers,
Stu
Cheers,
Stu
That's what I did. You can route the wires through the bulkhead where the bonnet cable goes, the grommet has some spare room.
