Dead easy Clart, remove the T20s at the front of the arch liner, and pull it back slightly, then 2 X 10mm bolts inside each arch liner (at the top going upwards where the wing joins the bumper. Then there is a T20 screw either side underneath where the arch liner is attached to the bumper. 2 X 10mm bolts underneath towards the centre and set back slightly, on the black trim underneath. Pop the bonnet and remove the 2 X clips in the black trim going onto the T piece, then lever the bumper forward / outwards either side at a time, best with a mate on one side, unclip fog lights. Done - 10 mins max.
