Mate my email just bust, lucky i copied it.......
reply to you:
"Hello mate,
he is very interested, but his only concern is the ECU. Since its running fly by wire, what ecus could you use? of could you convert it to a mechanical throttle with a potensiometer. Some pics of the ECU and plenum and throttle assembly would be great pleas, and any of the really techy bits that might feature on it...although its only a turbo. oh, and he is also interested in the turbo bottom end and gearboxes.....do the boxes bolt straight onto the f4r and existing clio shafts and mounts?
Would you be able to use the homologation ecu with it? i.e. use it as a base setting and tweek it from there? or is it impossible to use that ecu?
Cheers so much mate!!!!!
Ben"
