FAO FK Coilover owners...
Rob
This is for those that have dampening adjustment only ...
Has anyone got the info on how they're adjusted?
I've either lost, or never had mine...?
Basically, the little "bit" on top of the struts pops up and down...
Do I need to up or down to adjust?
Also, which way makes it softer and which way harder??
All help appreciated. Cheers.
Hi Rob. From memory anti clockwise is to make it firmer. Im assuming your talking about this part
Dan
I don't have a white thing, mine's just the thing underneath (which can pop up and down a bit (about 4mm))
I intend to just use pliers to adjust... lol!
Impreza, a bigger picture? I can't click that!
When you buy them they come with aout 4 of the white things, pliers will be fine.
Oooo I am excite:D When you set the firmness try and use a protractor with a hole in the middle you can get it equal firmness on each one then, or just count the turns.
